Go to main content
Sun Rack II Power Distribution Units User's Guide
Exit Print View
Updated: September 2020
Enabling and Configuring SNMP (Enhanced PDU)
The PDU metering unit supports Simple Network Management Protocol (SNMP). SNMP provides the ability to send traps, or notifications, when one or more conditions have been met. If you enable SNMP, the metering unit can send and receive traps to and from SNMP agents on the network.
Note -  These sections do not describe how to view SNMP trap information using an SNMP agent. Refer to your SNMP agent documentation for details on how to use it to view SNMP-based information.
