Restore the PDU to Factory Default Settings (Original PDU)
If you
need to correct a configuration error, or you want to clear the PDU
before
moving it to a different rack, you can restore the PDU metering unit
back to its
factory settings.
After restoring the unit, all network and configuration settings reset back to
their default values (for example, admin is the only user and the IP address returns
to 192.168.0.1). All settings that you set for your environment
are lost.
Note -
Restoring the PDU to factory defaults will not reset the energy to
zero.
Log in to the PDU metering unit.
See Access a Metering Unit on the Network (Original PDU).
Click on the
Net Configuration link and log in as an admin user.
See Login Information.
Scroll down the page until you see the
Factory-Reset heading.
Click the Submit button to restore the PDU metering unit back to its default
factory settings.
