See:
Included with the PDU are two PDU mounting brackets, spring nuts, screws, and washers.
Install compact PDUs from the bottom of the rack up. For more information, see Compact PDU Installation Locations.
See Attach an Antistatic Wrist Strap and Attach a Grounding Strap.
Hold the rack template up to the rear rack frame and mark where to install the spring nuts (labeled “Bracket Assembly Point” on the rack template).
Insert the spring nuts in the frame channel at a 45-degree angle. You use these spring nuts to secure the mounting brackets to the rack frame.
Use the rack template or the illustration in Step 5 to determine the specific spring nut locations.
Ensure that the upturned side of the bracket faces the side of the PDU that contains the circuit breakers and standoff bolts.
