View Status Information on the LCD Screen (Original PDU)
When the PDU metering unit resets or powers on, you can view network
and firmware version level information on the LCD screen.
Reset the PDU metering unit.
See Reset the PDU Metering Unit (Original PDU) for instructions.
After the metering unit resets, the LCD screen displays information about
the unit.
The
screen displays the following information:
HW: x.x FW:x.x
DHCP: OFF (or ON)
MAC: xx-xx-xx-xx-xx-xx
IP: xxx.xxx.xxx.xxx
HTML: VALID
The following table describes the LCD screen information.
HW
Version of the PDU hardware.
FW
Version of the PDU firmware.
DHCP
MAC
MAC address
of the metering unit.
IP
IP address of the metering unit.
If DHCP is OFF, the IP
address
is an internally stored static
address.
If DHCP is ON, the IP address is set by the
DHCP server.
HTML
Displays VALID when the correct version of the HTML
pages is installed, INVALID when not.
