Monitor the Enhanced PDU (RS-232)
Using the
metering unit's RS-232, you can monitor how much power, energy, and
current the equipment attached to the PDU uses, as well as the voltage level
powering the equipment.
Connect an RS-232 cable between the SER MGT port and the host.
Configure the host's terminal or terminal emulator with settings.
See Terminal Configuration Settings.
When prompted, log in as an admin or
user.
See Login Information.
Familiarize yourself with the command options.
See Understanding CLI Commands.
