Included with the PDU are two PDU mounting brackets, a cable routing bracket, screws, and washers.
You can install up to two PDUs, one per side, into the Sun Rack II cabinet. You can install these PDUs anywhere between the rear RETMA rail and the rack's rear frame. Provide adequate space to route the power input lead cords and any equipment data cables.
See Attach an Antistatic Wrist Strap and Attach a Grounding Strap.
See the following figure, panels 1 and 2.
Each mounting bracket contains two additional screw holes used to secure a PDU to the bracket when a PDU ships in a rack from the factory. Ignore these shipping screw holes when installing the PDU into the rack.
