Exit Print View
The switch has a default command prompt, which can be changed to a custom prompt.
If the Custom Prompt checkbox and Custom Prompt field are filled, the pane displays the custom prompt.
Enable a Custom CLI Prompt (Oracle ILOM Web)
Set a Custom CLI Prompt (Oracle ILOM Web)
Disable a Custom CLI Prompt (Oracle ILOM Web)
