When a log file gets large, you might want to clear it to facilitate locating and managing log contents. If you clear a log, it begins to fill again when new events occur.
-> set /SP/logs/audit/ clear=true Are you sure you want to clear /SP/logs/audit (y/n)? y Set 'clear' to 'true' ->
-> set /SP/logs/event clear=true Are you sure you want to clear /SP/logs/event (y/n)? y Set 'clear' to 'true' ->
-> set /System/Log/ clear=true -> Are you sure you want to clear /System/Log (y/n)? y ->
