If your network uses LDAP over SSL user domains, you must configure those domains on the switch so that members of the domains can access the switch.
Domains configured on the LDAP over SSL server must match the domains configured on the switch.
The user domain must comply with standard LDAP over SSL name formats for user domains.
The switch supports a maximum of five groups.
The pane scrolls to the User Domains section.
A pop-up window is displayed.
UID format, which is UID, OU, DC, and DC suffix.
DN format, which is CN, OU, DC, and DC suffix.
Optional Searchbase format, which is UID, OU, DC, DC suffix, and BASE.
