Typically, RADIUS networks have multiple alternate RADIUS servers to avoid a single point of failure. The switch supports a maximum of five RADIUS servers, plus the primary. Use this task to configure alternate RADIUS servers.
-> set /SP/clients/radius/alternateservers/Xaddress=IP_address ->
where:
X is a number from 1 to 5 for each alternate RADIUS server.
IP_address is the IP address of the alternate server.
For example, to set alternate server 1 with an address of 123.45.67.89, type:
-> set /SP/clients/radius/alternateservers/1 address=123.45.67.89 Set 'address' to '123.45.67.89' ->
-> set /SP/clients/radius/alternateservers/Xport=number ->
where:
number is the port number the alternate server will use for communication.
For example, to set alternate server 1 to use port 130, type:
-> set /SP/clients/radius/alternateservers/1 port=130 Set 'port' to '130' ->
-> set /SP/clients/radius/alternateservers/Xsecret=passworded ->
where:
For example, to set alternate server 1 to use the secret openplease, type:
-> set /SP/clients/radius/alternateservers/1 secret=openplease Set 'secret' to 'openplease' ->
