LDAP over SSL properties can be displayed for various groups, user domains, user mappings, alternate LDAP over SSL servers, and certificates on alternate servers. For each, a maximum of 5 instances is supported.
-> show -d properties /SP/clients/ldapssl/admingroups/X ->
where X is 1 through 5 for the administrator group.
For example, to display administrator group 1's properties, type:
-> show -d properties /SP/clients/ldapssl/admingroups/1 /SP/clients/ldapssl/admingroups/1 Properties: name = (none) ->
-> show -d properties /SP/clients/ldapssl/customgroups/X ->
where X is 1 through 5 for the custom group.
For example, to display custom group 1's properties, type:
-> show -d properties /SP/clients/ldapssl/customgroups/1 /SP/clients/ldapssl/customgroups/1 Properties: name = (none) roles = (none) ->
-> show -d properties /SP/clients/ldapssl/opergroups/X ->
where X is 1 through 5 for the operator group.
For example, to display operator group 1's properties, type:
-> show -d properties /SP/clients/ldapssl/opergroups/1 /SP/clients/ldapssl/opergroups/1 Properties: name = (none) ->
-> show -d properties /SP/clients/ldapssl/userdomains/X ->
where X is 1 through 5 for the user domain.
For example, to show user domain 1's properties, type:
-> show -d properties /SP/clients/ldapssl/userdomains/1 /SP/clients/ldapssl/userdomains/1 Properties: domain = (none) ->
-> show -d properties /SP/clients/ldapssl/alternateservers/X ->
where X is 1 through 5 for the alternate server.
For example, to display alternate server 1's properties, type:
-> show -d properties /SP/clients/ldapssl/alternateservers/1 /SP/clients/ldapssl/alternateservers/1 Properties: address = (none) port = 0 ->
-> show -d properties /SP/clients/ldapssl/alternateservers/X/cert ->
For example, to display alternate server 1's certificate, type:
-> show -d properties /SP/clients/ldapssl/alternateservers/1/cert /SP/clients/ldapssl/alternateservers/x/cert Properties: certstatus = certificate not present clear_action = (Cannot show property) issuer = (none) load_uri = (Cannot show property) serial_number = (none) subject = (none) valid_from = (none) valid_until = (none) version = (none) ->
-> show -d properties /SP/clients/ldapssl/optionalUserMapping /SP/clients/ldapssl/optionalUserMapping Properties: attributeInfo = (none) binddn = (none) bindpw = (none) searchbase = (none) state = disabled ->
