The switch has an Ethernet switch chip, also known as the EMS chip, which is networking switch 0. By default, this switch is brought online whenever the switch is powered on. While the switch is running, you can use this task to reset the EMS.
-> reset /System/Networking/Switches/Switch_0 Are you sure you want to reset /System/Networking/Switches/Switch_0 (y/n)? y ->
-> reset /System/Networking/Switches/Switch_0/sefos Are you sure you want to reset /System/Networking/Switches/Switch_0/sefos (y/n)? y ->
