If your network uses LDAP over SSL custom groups, you must configure those groups on the switch so that members of the custom groups can access the switch.
Custom groups configured on the LDAP over SSL server must match the groups configured on the switch.
Group names must comply with standard LDAP over SSL name formats for custom groups.
The switch supports a maximum of five groups.
The pane scrolls to the Custom Groups section.
A pop-up window is displayed.
When entering the name, use commas to separate each information element, and do not use spaces. For example, CN=SpCustom,OU=Groups,DC=domain,DC=companyq,DC=com.
Administrator or Operator to set either role and the predefined privileges for it.
None (No Assigned Roles) to have the LDAP user's role assigned by the LDAP server.
Advanced Roles to have a configurable set of privileges assigned to the LDAP user.
For more information, see User Roles and Permissions.
