As part of configuring LDAP over SSL properties, specify the following properties:
Server and port on which LDAP over SSL communication occurs.
Timeout for communication.
Specific roles and privileges that the user has on the switch.
Whether certificates are required (strict certificate mode).
-> set /SP/clients/ldapssl address=123.45.67.89 Set 'address' to '123.45.67.89' ->
-> set /SP/clients/ldapssl port=188 Set 'port' to '188' ->
-> set /SP/clients/ldapssl/ timeout=10 Set 'timeout' to '10' ->
-> set /SP/clients/ldapssl/ defaultrole=s Set 'defaultrole' to 's' [os] ->
For the role, you can use the characters of the aucros string to enable the respective abilities. See User Roles and Permissions.
-> set /SP/clients/ldapssl/ logdetail=value ->
where value is:
high, medium, low, or trace for more or less information in the log.
none for either no details, or to completely disable logging.
For example, to include the most amount of information, type:
-> set /SP/clients/ldapssl/ logdetail=high Set 'logdetail' to 'high' ->
-> set /SP/clients/ldapssl/ strictcertmode=enabled Set 'strictcertmode' to 'enabled' ->
Manage an LDAP over SSL Server's Certificate (Oracle ILOM CLI)
Manage Certificates for Alternate LDAP over SSL Servers (Oracle ILOM CLI)
Configure an LDAP over SSL Administrator Group (Oracle ILOM CLI)
Configure an LDAP over SSL Optional User Mapping (Oracle ILOM CLI)
Display the Oracle ILOM LDAP over SSL Client Information (Oracle ILOM CLI)
