Use this task to configure general SNMP properties such as enabling the SNMP service or selectively enabling SNMP v1, v2c, or v3. SNMP v1 and v2c are supported by the switch even though they are not secure. If you enable SNMP v1 or v2c, you are prompted with warning text, and must confirm that you want to use these versions of the protocol.
-> set /SP/services/snmp servicestate=enabled Set 'servicestate' to 'enabled' ->
-> set /SP/services/snmp/ sets=disabled Set 'sets' to 'disabled' ->
-> set /SP/services/snmp v2c=enabled ********* WARNING ********* Use of SNMP v1 or v2c protocols is insecure. Are you sure you want to set v2c=enabled (y/n)? y Set 'v2c' to 'enabled' ->
The switch can support multiple versions of SNMP simultaneously.
-> set /SP/services/snmp/ engineid=12345 Set 'engineid' to '12345' ->
