Display the text string used to identify the source of the
trap, typically the host name.
accessible-for-notify
sunHwTrapSystemIdentifier
Display the name of the component that is the source of the
trap.
sunHwTrapComponentName
Display the threshold type that the sensor is
reporting.
sunHwTrapThresholdType
Display the threshold value that has been exceeded.
sunHwTrapThresholdValue
Display the threshold sensor's reading at the time of the
trap.
sunHwTrapSensorValue
Display the name of a component that is suspected of causing a
fault.
sunHwTrapSuspectComponentName
Display a hierarchical classification string indicating the
type of problem detected, as reported by the fault management
subsystem, such as, for example, the Oracle Solaris fault
manager.
sunHwTrapFaultClass
Display the percentage likelihood that the component is the
source of the problem.
sunHwTrapFaultCertainty
Display an optional textual description that provides
additional information relevant to this notification.
sunHwTrapAdditionalInfo
Display the object in the
entPhysicalTable to which the
notification applies.
sunHwTrapAssocObjectId
Display the new value of the high availability state after a
high availability state change has occurred.
sunHwTrapNewHAState
Display the old value of the high availability state after a
sunHwTrapOldHAState
Display an indication of the severity of the
notification.
sunHwTrapSeverity
Display the text string containing the chassis serial
number.
sunHwTrapChassisId
Display the text string containing the product name.
sunHwTrapProductName
Display an indication as to why the component was
disabled.
sunHwTrapDisableReason
Display the states a hard drive can be in when hard drive
status is reported.
sunHwTrapHardDriveState
Display the message ID that can be used to get additional
information about the problem from Oracle's knowledge article
database.
sunHwTrapFaultMessageID
Display the universal unique identifier that was assigned to
this fault.
sunHwTrapFaultUUID
Display the message used by the test trap.
sunHwTrapTestMessage
Display the probable cause for hard drive error.
sunHwTrapHardDriveProbableCause
Display the probable cause for drive controller error.
sunHwTrapDriveControllerProbableCause
Display the probable cause for storage volume error.
sunHwTrapStorageVolumeProbableCause
Display the time stamp for when the fault occurred.
sunHwTrapEventTime
Display the name and version of the software component that
generated this fault event.
sunHwTrapDiagEntity
Display a textual description of the fault.
sunHwTrapFaultDescription
Display a knowledge article URL.
sunHwTrapKaUrl
Display the number of suspected faults diagnosed as the cause
of given set of reported hardware errors.
sunHwTrapSuspectCnt
Display the hostname of the SP or system.
sunHwTrapHostname
Display the product manufacturer.
sunHwTrapProductManufacturer
Display the product serial number.
sunHwTrapProductSn
Display the product part number.
sunHwTrapProductPn
Display a text string containing the chassis manufacturer,
which might differ from the
sunHwTrapProductManufacturer.
sunHwTrapChassisManufacturer
Display a text string containing the chassis name, which might
differ from the
sunHwTrapProductName.
sunHwTrapChassisName
Display a text string containing the chassis serial number,
sunHwTrapProductSn.
sunHwTrapChassisSn
Display a text string containing the chassis part number,
sunHwTrapProductPn.
sunHwTrapChassisPn
Display a text string containing the top-level product
manufacturer, which might differ from the
sunHwTrapChassisManufacturer.
sunHwTrapTopProductManufacturer
Display a text string containing the top-level product name,
sunHwTrapChassisName.
sunHwTrapTopProductName
Display a text string containing the top-level product serial
number, which might differ from the
sunHwTrapChassisSn.
sunHwTrapTopProductSn
Display a text string containing the top-level product part
sunHwTrapChassisPn.
sunHwTrapTopProductPn
Display a text string containing the simple data model
component location.
sunHwTrapSystemComponentLocation
subsystem name.
sunHwTrapSubSystem
Display a text string containing a fully-qualified path for a
simple data model component.
sunHwTrapSystemComponentPath
Display a text string containing the Oracle ILOM firmware
version.
sunHwTrapFirmwareVersion
build number.
sunHwTrapFirmwareBuild
build date.
sunHwTrapFirmwareDate
Display a text string containing the BIOS version.
sunHwTrapBIOSVersion
version.
sunHwTrapILOMVersion
