(Optional) Configure LDAP over SSL User Mappings (Oracle ILOM Web)
LDAP over SSL user mappings enable converting simple login names to the
distinguished names (DNs) for user credential validation.
Note -
Configure the user mapping properties through a separate pop-up
window.
Choose ILOM Administration→User Management, and click the LDAP
over SSL tab.
Click Configure for Optional User Mapping.
Select the Enabled checkbox for State.
In the Attribute Info field, type the object class and UID.
For example, the object class would be person,
and the UID would be the person's name.
In the Searchbase field, type the OU, DC, and DC suffixes.
For example, the OU could be an organization within a company, the DC
could be the company name, and the DC suffix could be
com.
In the Bind DN field, type the OU, DC, and DC suffixes.
com.
In the Bind Password field, type the password.
Click Save.
