Modify SNMP Service Communities (Oracle ILOM Web)
Use this task to change an existing SNMP v1 or v2c community.
Choose ILOM Administration→Management Access, and click the SNMP
tab.
Click the Communities link.
The page scrolls to the SNMP Communities table.
Select the community that you want to modify, then click Edit.
A pop-up window prompts you for confirmation.
Select the permissions from the Permission drop-down menu.
Click Save.
