-> set /SP/services/snmp/users/username property=value property=value ...
where:
username is the name of the SNMP user to modify.
property is the parameter of the SNMP user to configure.
value is the value of the property to configure.
These properties are supported:
authenticationpassword – value is the password used for authentication (8 to 12 characters).
authenticationprotocol – value is the protocol used for authentication.
permission – value is permission granted to the SNMP user.
privacypassword – value is the password used for privacy (exactly 8 characters).
privacyprotocol – value is the protocol used for privacy.
For example, to configure the snmpuser with read and write permissions, type:
-> set /SP/services/snmp/users/snmpuser permission=rw Set 'permission' to 'rw' User /SP/services/snmp/users/snmpuser properties were updated successfully ->
