Mounting the OSA USB Flash Drive
Before you can access the OSA
USB flash drive through Oracle VM 3.3, Oracle Solaris 11.2, or Linux
operating systems, you must first mount the USB flash drive.
Choose one of the following procedures to mount the OSA USB flash drive:
Note -
Currently you cannot directly mount the OSA USB flash drive if the system is using
the VMware ESXi 5.0 virtual machine software. Go to My Oracle Support to retrieve
the required drivers for the VMware ESXi software.
