Use this method to log in to the Oracle ILOM CLI when you are logging in over the network.
Use this syntax:
$ ssh username@SP_IPaddress
where username is a user account and SP_IPaddress is the IP address of the SP.
The default user name is root and the default password is changeme.
The CLI prompt appears (-> is the default prompt). You are connected to the SP where you perform Oracle ILOM CLI commands.
For example:
% ssh root@10.153.113.77 Password: Oracle(R) Integrated Lights Out Manager Version 3.2.4.32 r97913 Copyright (c) 2015, Oracle and/or its affiliates. All rights reserved. Warning: password is set to factory default. Hostname: ORACLESP-12345N6789 ->
