Use this procedure to set the BIOS settings to factory default settings using the BIOS Setup utility.
![]() | Caution - Resetting the BIOS to factory default values overwrites any custom BIOS settings. |
See Accessing BIOS.
A message appears prompting you to continue this operation by selecting OK or to cancel the operation by selecting Cancel.
The BIOS Setup utility window appears with the cursor highlighting the first value on the window.
