An example of how this command displays the storage devices on the server is shown below.
# lsscsi [0:0:0:0] disk SEAGATE ST360057SSUN600G 0805 /dev/sda [0:0:1:0] disk SEAGATE ST32000SSSUN2.0T 0313 /dev/sdb [0:0:2:0] disk SEAGATE ST32000SSSUN2.0T 0313 /dev/sdc [0:0:3:0] disk ATA INTEL HDDSA2BZ30 0362 /dev/sdd [0:0:4:0] enclosu ORACLE BLADE14 0903 - [7:0:0:0] disk SUN StorEdge 3511 421F /dev/sde [7:0:0:1] disk SUN StorEdge 3511 421F /dev/sdf [7:0:0:2] disk SUN StorEdge 3511 421F /dev/sdg [7:0:0:3] disk SUN StorEdge 3511 421F /dev/sdh [9:0:0:0] disk SUN CSM200_R 0660 /dev/sdi [9:0:0:1] disk SUN CSM200_R 0660 /dev/sdj [9:0:0:2] disk SUN CSM200_R 0660 /dev/sdk [9:0:0:3] disk SUN CSM200_R 0660 /dev/sdl [9:0:0:4] disk SUN CSM200_R 0660 /dev/sdm [9:0:0:5] disk SUN CSM200_R 0660 /dev/sdn [11:0:0:0] disk ORACLE SSM PMAP /dev/sdo
The OSA USB flash drive is the disk labelled ORACLE SSM and in this example is mapped to /dev/sdo.
An example of the output produced by this command is shown below.
# fdisk -l /dev/sdo Disk /dev/sdo: 3880 MB, 3880452096 bytes 4 heads, 32 sectors/track, 59211 cylinders Units = cylinders of 128 * 512 = 65536 bytes Device Boot Start End Blocks Id System /dev/sdo1 * 17 57344 3668992 ef EFI (FAT-12/16/32)
The name of the partition is in the Device column. For this example, it is /dev/sdo1.
For example:
# mkdir /mnt/OSA
Here is an example of a mount command:
# mount -t vfat -o codepage=850 /dev/sdo1 /mnt/OSA # ls /mnt/OSA boot Firmware LiveOS OracleVM syslinux.cfg Documentation ldlinux.sys manifest.xml readme.html Versions.txt EFI Linux Oracle Solaris Windows #
The OSA USB flash drive is now mounted at the location specified.
