Netra Server X5-2 Administration Guide
Exit Print View
Updated: October 2016
Glossary
A
ACPI
Advanced Configuration and Power Interface.
ANSI SIS
American National Standards Institute Status Indicator Standard.
ASF
Alert standard format.
ASR
Automatic system recovery.
AWG
American wire gauge.
B
BAT
basic assurance test.
BIOS
Basic Input Output System.
BMC
Baseboard management controller.
BOB
Memory buffer on board.
C
chassis
Refers to the server enclosure. For server modules, refers to the modular system enclosure.
CMA
Cable management arm.
D
DHCP
Dynamic Host Configuration Protocol.
DTE
Data terminal equipment.
E
ECC
Error-correcting code.
EIA
Electronics Industries Alliance.
ESD
Electrostatic discharge.
F
FRU
Field-replaceable unit.
G
GPT
GUID partition table.
GRUB
GRand Unified Bootloader. A GNU implementation that supports booting multiple OSs on a computer.
H
HBA
Host bus adapter.
HMP
Hardware Management Pack.
host
The part of the server with the CPU and other hardware that runs the Oracle Solaris OS and other applications. The term host is used to distinguish the primary computer from the SP. See SP.
I
ICMP
Internet Control Message Protocol.
IDE
Integrated Development Environment.
ID PROM
Chip that contains system information for the server or server module.
IP
Internet Protocol.
K
KVM
Keyboard, video, mouse. Refers to using a switch to enable sharing of one keyboard, one display, and one mouse with more than one computer.
L
LwA
Sound power level.
LRDIMM
Load Reduced DIMM.
M
MAC
Machine access code.
MAC address
Media access controller address.
MBR
Master boot record.
MSGID
Message identifier.
N
NEBS
Network Equipment-Building.
NET MGT
Network management port. An Ethernet port on the server SP.
NIC
Network interface card or controller.
NMI
Nonmaskable interrupt.
NVMe
A specification for accessing solid-state drives (SSDs) attached through the PCI Express (PCIe) bus. "NVM" is an acronym for non-volatile memory, which is used in SSDs.
O
OBP
OpenBoot PROM.
Oracle ILOM
Oracle Integrated Lights Out Manager. Oracle ILOM firmware is preinstalled on a variety of Oracle systems. Oracle ILOM enables you to remotely manage your Oracle servers regardless of the state of the host system.
Oracle Solaris OS
Oracle Solaris operating system.
OS
Operating system.
OSA
Oracle System Assistant.
P
PCI
Peripheral component interconnect.
PDB
Power distribution board.
PMR
Physical media request.
POST
Power-on self-test.
PROM
Programmable read-only memory.
PSH
Predictive self healing.
PXE
Preboot eXecution environment.
Q
QSFP
Quad small form-factor pluggable.
R
REM
RAID expansion module. Sometimes referred to as an HBA See HBA. Supports the creation of RAID volumes on drives.
RHEL
Red Hat Enterprise Linux.
RDIMM
Registered DIMM.
S
SAN
Storage area network.
SAS
Serial attached SCSI.
SATA
Serial advanced technology attachment.
SCC
System configuration chip.
SER MGT
Serial management port. A serial port on the server SP, the server module SP, and the CMM.
SLES
SUSE Linux Enterprise Server.
SMART
Self-Monitoring, Analysis, and Reporting Technology.
SNMP
Simple Network Management Protocol.
SP
Service processor. In the server or server module, the SP is a card with its own OS. The SP processes Oracle ILOM commands providing lights out management control of the host. See host.
SRU
Support Repository Update. Used to updated the Oracle Solaris OS.
SSD
Solid-state drive.
SSH
Secure shell.
T
TIA
Telecommunications Industry Association (Netra products only).
Tma
Maximum ambient temperature.
TPM
Trusted Platform Module.
U
UCP
Universal connector port.
UEFI
Unified Extensible Firmware Interface.
UI
User interface.
UL
Underwriters Laboratory Inc.
U.S. NEC
United States National Electrical Code.
UTC
Coordinated Universal Time.
UUID
Universal unique identifier.
V
VM
Virtual machine.
W
WDS
Windows Deployment Services.
WIM
Windows Imaging Format.
WWN
World wide name. A unique number that identifies a SAS target.
