Enable or Disable I/O Resource Allocation
Use this procedure to manage configuration settings for I/O devices, such as
I/O virtualization settings.
Access the BIOS Setup utility.
See Access the BIOS Setup Utility.
Use the left and right arrow keys to display the IO Menu.
See Navigate BIOS Setup Utility Menus.
Enable of disable the I/O resource.
Select Add In Cards.
Select a Slot.
Select IO Enable.
Select Enabled or Disabled.
Press F10 to save the changes and exit the BIOS Setup utility.
See Exit the BIOS Setup Utility.
