Netra Server X5-2 Administration Guide
Exit Print View
Updated: October 2016
Switch Between the Oracle ILOM CLI and the Host Console
When you are logged into the Oracle ILOM CLI, you can switch your connection to the host.
Tip  -  If you want to connect to the Oracle ILOM CLI and access the host console simultaneously, start two CLI sessions. Use one of the sessions to access the host console. Use the other session to access the Oracle ILOM CLI.
  1. Log in to the Oracle ILOM CLI.
    See Log In To the Oracle ILOM CLI (NET MGT) or Log In To the Oracle ILOM CLI (SER MGT).
  2. From Oracle ILOM, access the host.
    -> start /HOST/console
    Are you sure you want to start /HOST/console (y/n)? y
    Serial console started.  To stop, type ESC (
    The information displayed differs based on the state of the host:
    • Host is powering off – Serial console stopped.
    • Host is powered off – Nothing is displayed.
    • Host is booting – BIOS initialization windows are displayed. During this activity, you can enter various BIOS keys to enter the BIOS Setup utility or start OSA. See BIOS Key Mappings.
    • Host OS is booted – A message appears prompting you to specify user credentials.
  3. To switch back to Oracle ILOM, type:
    ESC (
Related Information
