Access the BIOS Setup utility.
See Access the BIOS Setup Utility.
Use the left and right arrow keys to select the different primary menu
options.
As you select each menu option, the top-level window for that menu option
appears.
To select an option on a primary menu, use the up and down arrow keys to
navigate to the options presented.
Only options that can be modified are highlighted when you press the up
and down arrow keys.
As you select the option, instructions for modifying the option
appear in the right column of the window.
If a field is a link to a submenu, a description of the submenu
content appears in the right column.
Modify the setup field by pressing the + or - keys or by pressing Enter
and selecting the desired option from the pop-up menus.
Press the Esc key to return from a submenu to the previous menu.
Note -
Pressing Esc from a primary menu is equivalent to selecting the
Discard Changes and Exit option from the Save & Exit menu.
Modify parameters as needed.
Exit the BIOS Setup utility.
See Exit the BIOS Setup Utility.
Note -
After modifying any BIOS settings and selecting Save Changes and Reset
from the Save & Exit menu, the subsequent reboot might take longer
than a typical reboot where no settings were modified. The additional
delay is required to ensure that changes to the BIOS settings are
synchronized with Oracle ILOM.
