BIOS Setup Utility Menus
The following table provides descriptions for the top-level BIOS Setup utility
menus.
Main
View and configure general product information, including time
and date, security settings, system serial number, and CPU and
DIMM information.
Advanced
View and configure information for the CPU, trusted computing,
USB, and other information. Set the IP address for the server
SP.
Boot
Enable or disable internal OSA support, set the boot mode to
Legacy BIOS or UEFI BIOS, and configure the boot device
priority.
IO
Manage configuration settings for I/O devices, such as I/O
virtualization settings, and enable and disable Option
ROMs.
Save & Exit
Save changes and exit, discard changes and exit, discard
changes, or restore the default BIOS settings.
To navigate the menus or options listed on a menu, use the arrow keys.
