Four Telco Alarm LEDs can be set to on and off by the user.
/SYS/CRITICAL_ALARM
/SYS/ALARM/MAJOR
/SYS/ALARM/MINOR
/SYS/ALARM/USER
When set to on, the corresponding front panel LED lights.
The CRITICAL_ALARM is also used to denote when standby power is not present due to a system power failure or disconnection.
You can manage the alarm indicators by using the Oracle ILOM CLI or by using an IPMItool utility.
-> set /SYS/CRITICAL_ALARM value=state -> set /SYS/ALARM/MAJOR value=state -> set /SYS/ALARM/MINOR value=state -> set /SYS/ALARM/USER value=state
Replace state with either on or off.
Oracle ILOM documentation library at: http://www.oracle.com/goto/ILOM/docs
