Oracle ILOM Overview
Oracle Oracle ILOM is system management
firmware that is preinstalled on the server's SP. Oracle ILOM enables you to manage and monitor the server, locally or
remotely, independent of the full power state of the server. As soon as standby power is
applied to the server, Oracle ILOM boots and is available.
You interact with Oracle ILOM using either a browser-based web interface or CLI. You
can also configure Oracle ILOM for interaction through the SNMP and IPMI interfaces.
For comprehensive information about Oracle ILOM, refer to the Oracle ILOM 3.2
documentation at:
http://www.oracle.com/goto/ILOM/docs
This table lists Oracle ILOM features and functionality:
Web interface and CLI
Display server information in a simple, standardized format that
is common across Oracle platforms.
Dedicated service processor and resources
Simple Oracle ILOM initial configuration
Downloadable firmware updates
Download firmware updates using the browser-based web
interface.
Remote hardware monitoring
Monitor (Solaris) system logs.
Monitor event logs.
Monitor audit logs.
Monitor CRUs and FRUs, including power supplies, fans,
HBAs, PCI devices, disks, CPUs, memory, and
motherboard.
Monitor environmental temperatures (component
temperatures).
Hardware and FRU inventory and presence
Identify installed CRUs and FRUs and their status.
Identify part numbers, versions, and product serial
numbers.
Identify NIC card MAC addresses.
Remote KVMS
Redirect the system serial console through serial port and
LAN.
Redirect the system keyboard, video, and mouse to a remote
client browser.
Redirect the OS graphical console to a remote client
browser.
Connect a remote CD, DVD, or floppy to the system for
remote storage.
Host power control and monitoring
Power the host on or off, either locally or
remotely.
Force power-off for emergency shutdown or perform a
graceful shutdown to shut down the host OS before
power-off.
Monitor power management and power history charts through
the web interface.
Configuration and management of user accounts
Configure local user accounts.
Configure LDAP, LDAP/SSL, RADIUS, and Active Directory
authentication.
Error and fault management
Log events in a consistent method for service data.
Monitor hardware and server-related errors, including ECC
memory errors, reported on a dedicated user interface page,
and into SP logs, syslog, and remote log host.
Oracle ILOM automatically clears most fault conditions
after you perform a service action to address the
fault.
System alerts, including SNMP traps, IPMI PETs, and alerts
Monitor components using industry-standard SNMP commands and the
IPMItool utility.
