Use administrative tools – You can obtain the server serial number using Oracle ILOM, or the BIOS Setup utility, or through OSA. See Obtaining Server Information.
View the serial number on the server – The server serial number is on a label on the front of the server in the lower left corner.
Use a barcode reader – The server serial number barcode is located on a label in the front of the server in the lower left corner.
Use an RFID reader – The server has an RFID tag on the front bezel that can be read by mobile or stationary RFID readers within a 9 ft. range. The serial number of the RFID tag is not the same as the serial number of the server, but can be used for asset inventory.
