sunHwTrapSensorNonCritThresholdExceeded
Upper noncritical threshold exceeded
Minor. A sensor has reported that its value has gone above an
upper noncritical threshold setting or below a lower noncritical
threshold setting. This generic sensor trap
is generated when the SNMP agent does not recognize the
component type. The sunHwTrapThresholdType
object indicates whether the threshold was an upper or
lower.
/SYS/VPS_CPUS
/SYS/VPS_MEMORY
sunHwTrapSensorThresholdOk
Upper noncritical threshold no longer exceeded
Informational. A sensor has reported that its value is in the
normal operating range. This generic 'sensor' trap is generated
when the SNMP agent does not recognize the component
type.
/SYS/VPS_CPUS
/SYS/VPS_MEMORY
sunHwTrapMemoryFault
event
fault.cpu.intel.quickpath.link_slow
Major. A memory component is suspected of causing a fault.
This generic 'component' trap is generated when the SNMP agent
does not recognize the component type.
/SYS/MB
sunHwTrapMemoryFaultCleared
event
Informational. A memory component fault has been cleared. This
generic 'component' trap is generated when the SNMP agent does
/SYS/MB
event
fault.cpu.intel.quickpath.unknown-errcode
/SYS/MB
event
/SYS/MB
event
fault.memory.intel.dimm.none
/SYS/MB
event fault.memory.intel.dimm.none
/SYS/MB
event
fault.memory.intel.dimm.memtest-failed
/SYS/MB
event
/SYS/MB
event
fault.memory.intel.dimm.quadrank-3rd-slot
/SYS/MB
event
/SYS/MB
event
fault.memory.intel.dimm.ddr3u-unsupported
/SYS/MB
event
/SYS/MB
event
fault.memory.intel.mrc.unknown-errcode
/SYS/MB
event
/SYS/MB
event
fault.memory.intel.dimm.udimm-unsupported
fault.
/SYS/MB/P[0-x]/D[0-11]
event
cleared.
event
fault.memory.intel.dimm.sodimm-unsupported
fault.
event
cleared.
event
fault.memory.intel.dimm.4gb-fused
fault.
event
cleared.
event
fault.memory.intel.dimm.8gb-fused
fault.
event
cleared.
event
fault.memory.intel.dimm.incompatible
fault.
event
cleared.
event
fault.memory.intel.dimm.incompatible-maxranks
fault.
event
cleared.
event
fault.memory.intel.dimm.incompatible-quadrank
fault.
event
cleared.
event
fault.memory.intel.dimm.numranks-unsupported
fault.
event
cleared.
event
fault.memory.intel.dimm.speed-slow
fault.
event
cleared.
event
fault.memory.intel.dimm.disable-quadrank
fault.
event
cleared.
event
fault.memory.intel.dimm.population-invalid
fault.
event
cleared.
event
fault.memory.intel.dimm.out-of-order
fault.
event
cleared.
event
fault.memory.intel.dimm.category-unknown
fault.
event
cleared.
