BIOS Key Mappings
While the BIOS initializes, you use function keys to perform actions listed in
this table.
If you are using a terminal device that does not support function keys, instead
use the equivalent control key sequence.
Note -
When using the Oracle ILOM Remote Console, F10 is trapped by the local OS. You
must use the F10 option listed in the KVMS -> Virtual Keyboard menu that is
available at the top of the Remote Console application.
F1
Ctrl+Q
Not applicable.
Activate the Setup Utility Help menu.
F2
Ctrl+E
Enter BIOS Setup utility while the BIOS is performing the
power-on self-test (POST).
Not applicable.
F7
Ctrl+D
Not applicable.
Discard changes.
F8
Ctrl+P
Activate the BIOS Boot menu.
Not applicable.
F9
Ctrl+O
Starts the OS. BIOS boots to OSA, bypassing the current Boot
Priority List for this one-time boot method.
Activate Load Optimal Values menu.
F10
Ctrl+S
Not applicable.
Activate Save and Exit menu.
F12
Ctrl+N
Activate Network boot.
Not applicable.
