Access Add-On Card Configuration Utilities (BIOS)
Use this procedure if you need to access add-on card configuration utilities. This
procedure only applies to servers configured to use UEFI BIOS mode. For more
information about BIOS modes, refer to Server OS
Installation, setting up BIOS.
Note -
In Legacy BIOS mode, I/O adapter utilities are invoked during BIOS POST
progression using hot keys identified by the adapter's Option ROM during POST.
When the hot key is pressed, the adapter's specific configuration utility
interface is presented. The interface has a vendor-specific design.
Access the BIOS Setup utility.
See Accessing BIOS.
Use the left and right arrow keys to display the Advanced menu.
See Navigate BIOS Setup Utility Menus.
Under RunTime Uefi Drivers, a list of all controllable devices is
displayed.
Note -
The RunTime UEFI Drivers devices are displayed only after a UEFI boot.
Use the up and down arrow keys to highlight a device, and press Enter to
configure that device.
Press F10 to save the changes and exit the BIOS Setup utility.
