Fan Event Traps
Description – A fan speed sensor has
reported that its value has gone above an upper critical threshold setting or below
a lower critical threshold setting. The sunHwTrapThresholdType
object indicates whether the threshold was an upper or lower.
sunHwTrapFanSpeedCritThresholdExceeded
Lower critical threshold exceeded
Major
/SYS/MB/FM[0-4]/F[0-1]/TACH
sunHwTrapFanSpeedCritThresholdDeasserted
Lower critical threshold no longer exceeded
Informational
sunHwTrapFanSpeedFatalThresholdExceeded
Lower fatal threshold exceeded
Critical
sunHwTrapFanSpeedFatalThresholdDeasserted
Lower fatal threshold no longer exceeded
Informational
