If the server is running a Linux OS, you must mount the OSA USB flash drive before you use the filesystem to display or access its contents.
This procedure shows how to mount the OSA USB flash drive on a Linux OS.
#>mkdir /mnt/OSA #>mount LABEL=ORACLE_SSM /mnt/OSA #>cd /mnt/OSA #>ls -l total 916 drwxr-xr-x 2 root root 4096 Nov 21 07:42 boot drwxr-xr-x 3 root root 4096 Nov 21 07:42 Documentation drwxr-xr-x 3 root root 4096 Oct 26 21:05 EFI drwxr-xr-x 16 root root 4096 Nov 21 07:42 Firmware -r-xr-xr-x 1 root root 15218 Oct 26 19:10 ldlinux.sys drwxr-xr-x 5 root root 4096 Nov 21 07:41 Linux drwxr-xr-x 2 root root 4096 Oct 26 21:05 LiveOS -rwxr-xr-x 1 root root 787672 Nov 21 08:17 manifest.xml drwxr-xr-x 2 root root 4096 Nov 21 08:00 Oracle -rwxr-xr-x 1 root root 78879 Nov 21 07:42 readme.html drwxr-xr-x 4 root root 4096 Nov 21 07:41 Solaris -rwxr-xr-x 1 root root 263 Oct 26 21:05 syslinux.cfg -rwxr-xr-x 1 root root 3755 Nov 21 07:42 Versions.txt drwxr-xr-x 3 root root 4096 Nov 21 07:42 VMware drwxr-xr-x 4 root root 4096 Nov 21 07:42 Windows #>
The OSA USB flash drive is now mounted at the location specified.
