From the local server – Press the Power button on the front panel of the server to power off the server, then press the Power button again to power on the server.
From the Oracle ILOM web interface – Click Host Management → Power Control and select Reset from the Select Action list box.
From the Oracle ILOM CLI – Type: reset /System
From the rear of the server – Using a stylus or similar implement, press the Host reset button.
