gnome-system-monitor - view system processes and monitor system usage
gnome-system-monitor [gnome-std-options]
gnome-system-monitor(1) User Commands gnome-system-monitor(1)
NAME
SYNOPSIS
DESCRIPTION
The System Monitor application displays a list of system processes, and
monitors system usage. System Monitor shows which processes are running
and how the processes are related.
System Monitor also provides detailed information about individual pro-
cesses, and enables the user to control which processes are running.
System Monitor displays how much processor (CPU) capacity the system is
using, and how much disk space the system is using on each device.
System Monitor displays this information in a graphical interface so
that users can see what the system is doing. Users can then use the
same graphical interface to modify the behavior of the system.
OPTIONS
The following options are supported:
gnome-std-options Standard options available for use with most
GNOME applications. See gnome-std-options(7)
for more information.
ENVIRONMENT VARIABLES
See environ(7) for descriptions of the following environment variables
that affect the execution of gnome-system-monitor: NLSPATH.
EXIT STATUS
The following exit values are returned:
0 Application exited successfully
>0 Application exited with failure
ATTRIBUTES
See attributes(7) for descriptions of the following attributes:
|ATTRIBUTE TYPE | ATTRIBUTE VALUE |
|Availability | desktop/system-monitor/gnome-system-monitor |
|Stability | Pass-through volatile |
SEE ALSO
System Monitor Manual
Latest version of the GNOME Desktop User Guide for your platform.
top(1), prstat(8), attributes(7), environ(7), gnome-std-options(7)
NOTES
Written by Niall Power, Sun Microsystems Inc., 2003. Updated by Henry
Zhang, Sun Microsystems Inc., 2006.
Source code for open source software components in Oracle Solaris can
be found at https://www.oracle.com/downloads/opensource/solaris-source-
code-downloads.html.
This software was built from source available at
https://github.com/oracle/solaris-userland. The original community
source was downloaded from https://download.gnome.org/sources/gnome-
system-monitor/41/gnome-system-monitor-41.0.tar.xz.
Further information about this software can be found on the open source
community website at https://help.gnome.org/users/gnome-system-moni-
tor/.
Solaris 11.4 7 Apr 2017 gnome-system-monitor(1)
