Go to main content
SPARC M8 and SPARC M7 Servers Service Manual
Exit Print View
Updated: January 2022
PCIe Card Carrier LEDs and Controls
image:Illustration that shows the LEDs and indicators for the PCIe card                         carrier.
No.
LED
Icon
Description
1
Service Required (amber) and Locator LED
image:Icon for the Service Required LED
image:Icon for the Locator LED
The Service Required LED indicates that service is required.
The show faulty command provides details about any faults that cause this indicator to light.
The Locator LED blinks to indicate the locate functionality.
2
OK (green)
image:Icon for the OK LED
Indicates these conditions:
  • Off – PCIe card carrier is not running in its normal state.
  • Steady on – PCIe card is powered on and is running in its normal operating state. No service actions are required. You cannot remove the PCIe card.
3
Attention Required
ATTN
Indicates an operational fault. You can also press this button to alert the server to a newly installed PCIe card.
Related Information
