Go to main content
SPARC M8 and SPARC M7 Servers Service Manual
Exit Print View
Updated: January 2022
Verify the PCIe Card
Note -  Always update PCIe card firmware to the latest supported version. Refer to the PCIe card documentation for the firmware update instructions.
  1. Verify that the Fault LED is not lit and that the green Power LED is lit on the card that you installed.
    See PCIe Card Carrier LEDs and Controls.
  2. At a terminal, use the hotplug command to ensure that the card is connected.
    For example:
    # hotplug list /SYS/CMIOU0/PCIE1
           [/SYS/CMIOU0/PCIE1]  ENABLED
           network@0  <pci.0,0> ONLINE
           network@0,1  <pci.0,1> ONLINE
           network@0,2  <pci.0,2> ONLINE
           network@0,3  <pci.0,3> ONLINE
Related Information
