Enabling Disabled Components
The enablecomponent command
enables a disabled
component
by removing it from the ASR blacklist.
- At
the sc> prompt, enter the enablecomponent command.
sc> enablecomponent /SYS/MB/CMP0/BR1/CH0/D0
Chassis | major: /SYS/MB/CMP0/BR1/CH0/D0 has been enabled.
- After receiving confirmation
that the enablecomponent command is complete, reset
the server for so that the ASR command takes effect.
sc> reset
