Refer to the Integrated Lights Out Manager 2.0 (ILOM 2.0) Supplement for the Sun Netra T5440 Server for instructions.
The method you use to clear a fault depends on how the fault is identified by the showfaults command.
Examples:
-> show faulty Target | Property | Value --------------------+------------------------+-------------------------------- /SP/faultmgmt/0 | fru | /SYS/MB/CMP0/BR0/CH1/D0 /SP/faultmgmt/0 | timestamp | Dec 14 22:43:59 /SP/faultmgmt/0/ | sunw-msg-id | SUN4V-8000-DX faults/0 | | /SP/faultmgmt/0/ | uuid | 3aa7c854-9667-e176-efe5-e487e520 faults/0 | | 7a8a /SP/faultmgmt/0/ | timestamp | Dec 14 22:43:59 faults/0 | |
-> show faulty Target | Property | Value --------------------+------------------------+-------------------------------- /SP/faultmgmt/0 | fru | /SYS/MB/CMP0/BR1/CH0/D0 /SP/faultmgmt/0 | timestamp | Dec 21 16:40:56 /SP/faultmgmt/0/ | timestamp | Dec 21 16:40:56 faults/0 /SP/faultmgmt/0/ | sp_detected_fault | /SYS/MB/CMP0/BR1/CH0/D0 faults/0 | | Forced fail(POST)
-> set /SYS/MB/CMP0/BR0/CH0/D0 component_state=Enabled
-> set /SYS/keyswitch_state=Diag Set ???keyswitch_state' to ???Diag'
-> stop /SYS Are you sure you want to stop /SYS (y/n)? y Stopping /SYS -> start /SYS Are you sure you want to start /SYS (y/n)? y Starting /SYS
-> start /SYS/console
Watch the POST output for possible fault messages. The following output is a sign that POST did not detect any faults:
. . . 0:0:0>INFO: 0:0:0> POST Passed all devices. 0:0:0>POST: Return to VBSC. 0:0:0>Master set ACK for vbsc runpost command and spin...
-> set /SYS keyswitch_state=Normal Set ???ketswitch_state' to ???Normal'
# fmadm faulty
No memory faults should be displayed.
If faults are reported, refer to the diagnostics flowchart in Diagnostic Flowchart for an approach to diagnose the fault.
-> show faulty Target | Property | Value --------------------+------------------------+------------------------------- /SP/faultmgmt/0 | fru | /SYS/MB/CMP0/BR0/CH1/D0 /SP/faultmgmt/0 | timestamp | Dec 14 22:43:59 /SP/faultmgmt/0/ | sunw-msg-id | SUN4V-8000-DX faults/0 | | /SP/faultmgmt/0/ | uuid | 3aa7c854-9667-e176-efe5-e487e520 faults/0 | | 7a8a /SP/faultmgmt/0/ | timestamp | Dec 14 22:43:59 faults/0 | |
-> set /SYS/MB/CMP0/BR0/CH1/D0 clear_fault_action=True Are you sure you want to clear /SYS/MB/CMP0/BR0/CH1/D0 (y/n)? y Set 'clear_fault_action' to 'true
Use the same UUID that was displayed from the output of the ILOM show faulty command.
# fmadm repair 3aa7c854-9667-e176-efe5-e487e520
