1.5.1 Controlling How POST Runs
The server
can be configured for normal, extensive, or no POST execution. You
can also control the level of tests that run, the amount of POST
output that is displayed, and which reset events trigger POST by
using ALOM CMT CLI variables.
ALOM CMT CLI Parameters Used for POST Configuration lists the ALOM CMT CLI
variables used to configure POST. Flowchart of ALOM CMT CLI Variables for POST Configuration shows
how the variables work together.
Table 1-7 ALOM CMT CLI Parameters Used for POST Configuration
setkeyswitch |
normal |
diag |
The system runs POST based on predetermined settings. |
stby |
The system cannot power on. |
locked |
The system can power on and run POST,
but no flash updates can be made. |
off |
POST does not run. |
normal |
Runs POST according to diag_level value. |
service |
Runs POST with preset values for diag_level and diag_verbosity. |
max |
If diag_mode = normal,
runs all the minimum tests plus extensive CPU and memory tests. |
min |
runs minimum set of tests. |
none |
Does not run POST on reset. |
user_reset |
Runs POST upon user-initiated resets. |
power_on_reset |
Only runs POST for the first power on.
This option is the default. |
error_reset |
Runs POST if fatal errors are detected. |
all_resets |
Runs POST after any reset. |
none |
No POST output is displayed. |
min |
POST output displays functional tests
with a banner and pinwheel. |
normal |
POST output displays all test and informational messages. |
max |
POST displays all test, informational,
and some debugging messages. |
Figure 1-8 Flowchart of ALOM CMT CLI
ALOM CMT CLI Parameters and POST Modes shows typical combinations
of ALOM CMT CLI variables and associated POST modes.
Table 1-8 ALOM CMT CLI Parameters and POST Modes
normal |
off |
service |
normal |
keyswitch_state The keyswitch_state parameter,
when set to diag, overrides all the other ILOM
POST variables.
normal |
normal |
normal |
diag |
max |
n/a |
max |
max |
power-on-reset error-reset |
none |
all-resets |
all-resets |
normal |
n/a |
max |
max |
Description of POST execution |
This is the default POST configuration.
This configuration tests the system thoroughly, and suppresses some
of the detailed POST output. |
POST does not run, resulting in quick
system initialization. This is not a suggested configuration. |
POST runs the full spectrum of tests with
the maximum output displayed. |
