Use the clear_fault_action property of a FRU to manually clear PSH diagnosed faults from the service processor without a FRU replacement or if the service processor was unable to automatically detect the FRU replacement.
Example showing a PSH diagnosed fault being cleared manually using the clear_fault_action property of the FRU:
-> set /SYS/MB/CMP0/BR0/CH0/D0 clear_fault_action=True Are you sure you want to clear /SYS/MB/CMP0/BR0/CH0/D0 (y/n)? y Set 'clear_fault_action' to 'true'
