This procedure assumes that the Solaris OS is running on the server, and that you have access to the Solaris command line.
% pkginfo -l SUNWvts SUNWvtsr SUNWvtsts SUNWvtsmn
The following table lists SunVTS packages:
If SunVTS is not installed, you can obtain the installation packages from the following places:
Solaris Operating System DVDs
From the Sun Download Center: http://www.sun.com/oem/products/vts
The SunVTS 6.0 PS3 software, and future compatible versions, are supported on the server.
SunVTS installation instructions are described in the SunVTS User's Guide.
ERROR: information for "SUNWvts" was not found ERROR: information for "SUNWvtsr" was not found ...
