![]() | Caution - When performing the following steps, use special care to enter the correct numbers. Once the power distribution board has been programmed with a chassis serial number or server part number, the number cannot be changed. |
sc> setsc sc_servicemode true Warning: misuse of this mode may invalidate your warranty. sc> setcsn -c chassis_serial_number Are you sure you want to permanently set the Chassis Serial Number to chassis_serial_number [y/n]? y setcsn: Chassis serial number recorded. sc> setcpn -p chassis_part_number Are you sure you want to permanently set the Chassis Part Number to chassis_part_number [y/n]? y setcpn: Chassis part number recorded. sc> showplatform Sun-Netra-T5440 Chassis Serial Number: chassis_serial_number Domain Status ------ ------ SO Running sc> setsc sc_servicemode false
