To obtain support for your system, you need your chassis serial number. The chassis serial number is located on a sticker that is on the front of the server and another sticker on the side of the server. You can also run the ALOM CMT CLI showplatform command to obtain the chassis serial number.
For example:
Example 1-16 Obtaining the Chassis Serial Number With the showplatform Commandsc> showplatform SUNW,Sun-Netra-T5440 Chassis Serial Number: 0529AP000882 Domain Status ------ ------ S0 OS Standby sc>
