The Automatic System Recovery (ASR) feature enables the server to automatically configure failed components out of operation until they can be replaced. In the server, theASR feature manages the following components:
UltraSPARC T2 processor strands
Memory FB-DIMMs
I/O bus
The database that contains the list of disabled components is called the ASR blacklist (asr-db).
In most cases, POST automatically disables a faulty component. After the cause of the fault is repaired (FRU replacement, loose connector reseated, and so on), you must remove the component from the ASR blacklist.
The ASR commands (ASR Commands ) enable you to view, and manually add or remove components from the ASR blacklist. You run these commands from the ALOM CMT CLI sc> prompt.
