Oracle® InfiniBand Switch IS2-46 Service Manual
Exit Print View
Updated: September 2016
Begin the Diagnostic Process
Follow this process when you are informed of or recognize a problem.
  1. Are you sure you know the cause of the problem?
  2. Is the cause from a software failure or hardware failure?
    • Hardware – Go to Step 3.
    • Software – The solution is beyond the scope of this document.
      Refer to the Oracle EDR InfiniBand Switch and Virtualized I/O Systems Administration Guide and the software troubleshooting documentation. If necessary, contact your authorized Oracle Service Provider.
  3. Are you sure you know the solution to the hardware problem?
  4. Replace the problematic component.
    See Faulted Item Replaceable Components for links to component service tasks.
  5. Are you in the physical presence of the switch?
Related Information
