Locate the Switch
You can use the Locate LED to pinpoint the location of a switch. This task is
helpful when you need to identify one particular switch from many other rack
components.
Note -
Unlike other Oracle products, the Locate LED is only at the rear of the switch
and does not have button functionality. You control the Locate LED through
Oracle ILOM.
Access the Oracle ILOM CLI.
See Accessing the SP.
Set the Locate LED to blink.
-> set /SYS/LOCATE value=Fast_Blink
The white Locate LED blinks.
After servicing the switch with the blinking Locate LED, turn the LED
off.
-> set /SYS/LOCATE value=off
